Nr 240
Frank
Nr 240
#1 Beitrag von Frank » 21. Jan 2010, 23:22
wie heißt diese Stadt und wo stehe ich beim Fotografieren?
Womonaut
#2 Beitrag von Womonaut » 22. Jan 2010, 17:40
Hi Frank,
also so richtig geprüft habe ich das jetzt nicht, aber "an educated guess" wäre Neapel?
David
....allen Ballast verkloppen und dann nur noch Womo-Reisen? Ein verführerischer Gedanke...
Frank
#3 Beitrag von Frank » 22. Jan 2010, 23:18
wrong guess!!completly wrong!!
my photography position is on a very famous building in europe
Zuletzt geändert von Frank am 22. Jan 2010, 23:33, insgesamt 1-mal geändert.
w.w.w
#4 Beitrag von w.w.w » 22. Jan 2010, 23:20
Hallo David,
hatte ich auch vermutet.
Mit besten Grüßen
wolf
Frank
#5 Beitrag von Frank » 23. Jan 2010, 00:32
eine kleine Drehung nach rechts..
Womonaut
#6 Beitrag von Womonaut » 23. Jan 2010, 09:24
Hi Frank:
We can observe in your second picture the following:
QUOTE:
The Torre Agbar of the French architect Jean Nouvel has taken a prominent place in the skyline of Barcelona. Nobody wants to believe anymore that the iconography that the architect meant for the office tower was that of a fontein, a geiser, a shower. An appropriate iconography for the company the building is for; the water company of Barcelona.
Now we still have to identify the position of your snap shot standing(s).
Regard
David
Womonaut
#7 Beitrag von Womonaut » 23. Jan 2010, 09:38
Frank,
identifying your position is more challenging. I suppose that you were standing somewhere west of the Torre Agbar....probably at a higher elevation or other tall building....difficult...
maybe around the "Monestir de Pedralbes" near the "Parque de la Oreneta"?
Regards
David
Womonaut
#8 Beitrag von Womonaut » 23. Jan 2010, 09:44
Frank,
my last "educated" guess would take us further south-west relative to the "penis" tower....
Barcelone: Musée Miro, Montjuïc which is standing on a hill high enough for the elevated pictures...
Regard
David
Lantenta
#9 Beitrag von Lantenta » 23. Jan 2010, 10:42
Zuletzt geändert von Lantenta am 22. Sep 2010, 10:33, insgesamt 2-mal geändert.
Frank
#10 Beitrag von Frank » 23. Jan 2010, 12:44
Frank hat geschrieben:wrong guess!!completly wrong!!
falsch geraten, komplett falsch
meine Fotografierposition ist auf einem sehr berühmten Gebäude in Europa
Hallo David
Barca ist richtig. Die Position sollte aber nun kein Problem mehr darstellen..
Die von Dir bereits genannten sind alle falsch.Allerdings ist "tall building" (hohes Gebäude) schon richtig
Klaudia
#11 Beitrag von Klaudia » 23. Jan 2010, 12:50
Vielleicht von der Sagrada Familia in Barcelona fotografiert?
von Klaudia und Martin
Hymis-Reisen
Frank
#12 Beitrag von Frank » 23. Jan 2010, 12:54
Martin&Klaudia hat geschrieben:Vielleicht von der Sagrada Familia in Barcelona fotografiert?
Bingo, gewonnen!!Glückwunsch
Frank
#13 Beitrag von Frank » 23. Jan 2010, 12:55
Hier isse..und von oben in den Türmen hab ich geknipst..oder wars die Rückseite? Hmm weiß nimmer..
Womonaut
#14 Beitrag von Womonaut » 23. Jan 2010, 15:17
Gratulation, sehr gut gelöst....
Mal ein wenig Englisch in einem Rätsel Forum sollte kein Problem darstellen....Englischkenntnisse kann man fast überall gerade auf Reisen gebrauchen....
Congratulation, well done....
English for a change surely should not characterize a large problem in a travel riddle panel, since English skills are of value in almost any journey...
IDEE: Vielleicht könnte man in diesem Forum darüber nachdenken, ob man sich nicht stärker international öffnen möchte...und einige bestimmte threads NUR in Englisch ausführen könnte....z.B. zu Stellplätzen in Europa...
David
Klaudia
#15 Beitrag von Klaudia » 23. Jan 2010, 15:32
Hallo David
Meine Englischkenntnisse würden dazu nicht mehr ausreichen und ich vermute, das es hier einigen so gehen würde. :wallb:
Die Idee ist ja nicht schlecht, besser fänd ich es dann aber, es gleich zweisprachig zu machen, so wie du in deinen letzten Beiträgen.
Wir überlegen jetzt mal, was wir als nächstes hier einstellen :cyclopsani:
Hymis-Reisen
